Level XIII
Parse in substitute
In Substitute, if I don't have a fixed number of symbols, is it possible to use a for loop and parse to generate the symbol names?
Something is wrong here:
myExpr=Expr(sum());
For( i=1, i<=10, i++, Insert Into (myExpr,parse("__x"||Char(i)||"__")));
Show(NameExpr(myExpr));
For( i=1, i<=10, i++, substitute (Name Expr(myExpr),parse("__x"||Char(i)||"__"),parse("y"||Char(i))));
Re: Parse in substitute
You aren't updating the value of myExpr
myExpr = Expr(Sum());
For(i = 1, i <= 10, i++,
	Insert Into(myExpr, Parse("__x" || Char(i) || "__"))
Show(Name Expr(myExpr));
	myExpr = Substitute(Name Expr(myExpr), Parse("__x" || Char(i) || "__"), Parse("y" || Char(i)))
Level XIII
oh, so close!
