uday_guntupalli
Level VIII
Parse XML Help
All,
   I have some XML, I would like to parse using JSL. I am not familiar with XML, so pardon my ignorance.
   <Table><Rule DayName=\!"Sunday\!" Val1=\!"1\!"/>
   What I tried is the following:
Parse XML( Test,
			On Element( "Table", Start Tag( New Table( XML Attr( "Table" ) ) ) ),
			On Element("Rule",End Tag( New Column( XML Attr( "DayName" ), Set Values( Parse( XML Text() ) ) ) ) )
  I know, I wold have to add one more rule using On Element to parse the "Val1" attribute, but that is not working, what I would like the output to be is :
Best
Uday
Craige_Hales
Re: Parse XML Help
test data
Test =
<Table>
    <Rule DayName="Sunday" Val1="1"/>
    <Rule DayName="Monday" Val1="2"/>
    <Rule DayName="Tuesday" Val1="3"/>
</Table>
You can get what you asked for like this:
Parse XML( Test,
    On Element( "Table", Start Tag( dt1 = New Table( XML Attr( "Table" ) ) ) ),
    On Element( "Rule", End Tag( New Column( XML Attr( "DayName" ), Set Values( Eval List( {XML Attr( "Val1" )} ) ) ) ) )
one wayone way
But I think a better intepretation of the file might look like this:
Parse XML( Test,
    On Element( "Table", Start Tag( dt2 = New Table( XML Attr( "Table" ), New Column( "DayName" ), New Column( "Val1" ) ) ) ),
    On Element(
        "Rule",
        End Tag(
            dt2 << addrow( 1 );
            dt2:DayName = XML Attr( "DayName" );
            dt2:Val1 = XML Attr( "Val1" );
Another wayAnother way
(You don't want the parse(...); the example in the scripting index that uses it also has a JSL matrix in the XML file that needs the parse. Your example has a single number, in quotation marks. You could use the num() function to make the conversion so the column would be numeric.   dt2:Val1 =num( XML Attr( "Val1" ));  )
Craige
Craige_Hales
Re: Parse XML Help
test data
Test =
<Table>
</Table>
Parse XML( Test,
one wayone way
Parse XML( Test,
    On Element(
        "Rule",
        End Tag(
            dt2 << addrow( 1 );
Craige
