Can we do a Panel Data analysis using JMP? Fixed Effects, Random Effects and Hausman Test? Also are there any JMP Add ins available for Econometric modeling? (ARCH, GARCH, etc)
JMP does not currently support the Hausman test, if you want to look at the effect of fixed and random effects you can compare different modelling approaches in the Fit Model platform. Since you are looking at econometric modelling it may be worth looking at our Time Series platform, and the new Prophet forecasting add-in in our marketplace.
Hope that helps,
Ben
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '846971' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '846971') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '846971') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
