Field Map
Hi Mark,
We wanted to compare between two seed types in potatoes (planting Cut seed vs planting whole seed). Cut seed is used as control which is a common practice. This trial was conducted at the grower’s field. The field was divided into two strips blocks, the first block (in yellow) was planted with control (cut seed) and the second block (light blue) was planted with the whole seed. These strip blocks are really long 400-foot. In total, twenty four samples (12 from each strip block) were harvested. Each sample was harvested from a 10-foot long row plot and converted the yield in CWT per acre. The field variation was huge. The trial was conducted at grower’s field. So, we could not randomize the treatments. I have analyzed the data using the paired t with distribution and test mean, see below:
My question:
I understand that we should use the paired t test.
One of the great statistician suggested that we should create an extra column frequency and use it for the analysis. I have analyzed the data with and without using the frequency.
I wanted to know which method is incorrect and why?
Which method is correct?
I would appreciate your time.
Best regards
- I have created difference and frequency columns and both
See the results below: They are significant P >0.0232
- I have created difference and frequency column but this time I did not use the frequency column
Results see below: Non significant P >0.1208
