Yass
PNG Export Issues for Dashboard in JMP 16
Hi everyone,
I have a question about saving a dashboard as a PNG in JMP 16. I found an example in an old question, but it doesn't work for me.
I received this response:
Unresolved name: dash at line 13 while accessing or evaluating "dash", dash/*###*/
at line 440 in D:\Project JMP\Scripts\PourcentageDeNokParJour.jsl.
results_table = Open( "D:/Project JMP/Tables Resultats NOK percentages/Results.jmp" );
dash = JMP App(
	Set Name( "Tableau de bord" ),
	Set Description( "Description" ),
	Auto Launch( 1 ),
	Snap To Grid( 1 ),
	Show Grid( 1 ),
	Show Properties( 0 ),
	Show Sources( 1 ),
	Group By Category( 0 ),
	Dashboard Mode( 1 ),
	Parameters,
	Tables(
		DataTable1 = GuiTable(
			Set Path(
				"/D:/Project JMP/Tables Resultats NOK percentages/Results.jmp"
			Set Label( "Results" ),
			Location( "Current Data Table" ),
			Invisible( 0 )
	Script(JSL Quote(// This script is executed when the application is run.
// Named objects have been created for the application modules
// (for example, "Module1") and the pre-defined object
// "thisApplication" refers to the application object itself.
// Variables and functions declared here are scoped to the
// Application namespace.
	Allocate(
		Module1 = Plan(
			PreAllocate,
			Script(JSL Quote(// This script is executed when a new module instance is
// created.  The pre-defined object "thisModuleInstance" refers
// to the instance object, but other objects such as boxes and
// scripts have not yet been created.  Variables declared here are
// scoped to the ModuleInstance namespace.
// This special function will receive parameters passed to CreateInstance()
OnModuleLoad({},
thisModuleInstance << Create Objects;
// After this point your module instance objects have been created
// and can be referred to by name (for example, "Button1").
Try(TabPage3 << Set Scriptable Object(thisApplication));
			Allocate(
				TabPage3 = Tab Page Box();
				Splitter1 = H Splitter Box();
				TabPage1 = Tab Page Box();
				Scroll1 = Scroll Box();
				Report1 = Platform(
					DataTable1,
					Graph Builder(
						Size( 815, 650 ),
						Fit to Window,
						Variables(
							X( :Date ),
							Y( :Percent NOK ICT ),
							Y( :Percent NOK FCT )
						Elements( Position( 1, 1 ), Line( X, Y, Legend( 13 ) ) ),
						Elements( Position( 1, 2 ), Line( X, Y, Legend( 14 ) ) ),
							Dispatch(
								"graph title",
								TextEditBox,
								{Set Text(
									"Percent NOK ICT &  FCT par rapport à Date"
				TabPage2 = Tab Page Box();
				Scroll2 = Scroll Box();
				Report2 = Platform(
					DataTable1,
					Graph Builder(
						Size( 851, 698 ),
						Fit to Window,
						Variables(
							X( :Date ),
							Y( :Total ICT ),
							Y( :NOK ICT, Position( 1 ) ),
							Y( :Total FCT ),
							Y( :NOK FCT, Position( 2 ) )
						Elements(
							Position( 1, 1 ),
							Bar(
								X,
								Y( 1 ),
								Y( 2 ),
								Legend( 11 ),
								Label( "Label by Value" )
						Elements(
							Position( 1, 2 ),
							Bar(
								X,
								Y( 1 ),
								Y( 2 ),
								Legend( 6 ),
							Dispatch(
								"graph title",
								TextEditBox,
								{Set Text(
									"NOK ICT et FCT / Total ICT et FCT par rapport à Date"
			Organize(
				Reparent( Scroll2( Report2 ) );
				Reparent( TabPage2( Scroll2 ) );
				Reparent( Splitter1( TabPage2 ) );
				Reparent( Scroll1( Report1 ) );
				Reparent( TabPage1( Scroll1 ) );
				Reparent( Splitter1( TabPage1 ) );
				Reparent( TabPage3( Splitter1 ) );
				Relocate( TabPage3( 0, 0 ) );
			Initialize(
				TabPage3 << Background Color( 2147483647 ),
				TabPage3 << Border( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
				TabPage3 << Enabled( 1 ),
				TabPage3 << Horizontal Alignment( "Default" ),
				TabPage3 << Margin( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
				TabPage3 << Padding(
				), TabPage3 << Text Color( 2147483647 ), TabPage3 << UI Only( 0 ),
				TabPage3 << Vertical Alignment( "Default" ),
				TabPage3 << Visibility( "Visible" ),
				TabPage3 << Set Min Size( 442, 139 ),
				TabPage3 << Set Max Size( 30000, 30000 ),
				TabPage3 << Set Stretch( {"Neutre", "Neutre"} ),
				TabPage3 << Title( "Total Production % & NOK % Dashboard" ),
				TabPage3 << Tip( "" ), TabPage3 << Icon( "" ),
				TabPage3 << Closeable( 0 ), TabPage3 << Moveable( 0 ),
				TabPage3 << Set Base Font( "Texte" ),
				TabPage3 << Set Font Scale( 1 ),
				Splitter1 << Background Color( 2147483647 ),
				Splitter1 << Border(
				), Splitter1 << Enabled( 1 ),
				Splitter1 << Horizontal Alignment( "Default" ),
				Splitter1 << Margin(
				Splitter1 << Padding(
				), Splitter1 << Text Color( 2147483647 ), Splitter1 << UI Only( 0 ),
				Splitter1 << Vertical Alignment( "Default" ),
				Splitter1 << Visibility( "Visible" ), Splitter1 << Dockable( 1 ),
				Splitter1 << Set Width( 1908 ), Splitter1 << Set Height( 728 ),
				Splitter1 << Set Sizes( {0.502347417840376, 0.497652582159624} ),
				Splitter1 << Set Min Size( 442, 113 ),
				Splitter1 << Set Max Size( 60003, 30000 ),
				Splitter1 << Set Stretch( {"Fenêtre", "Fenêtre"} ),
				Splitter1 << set horizontal( 1 ),
				TabPage1 << Background Color( 2147483647 ),
				TabPage1 << Border( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
				TabPage1 << Enabled( 1 ),
				TabPage1 << Horizontal Alignment( "Default" ),
				TabPage1 << Margin( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
				TabPage1 << Padding(
				), TabPage1 << Text Color( 2147483647 ), TabPage1 << UI Only( 0 ),
				TabPage1 << Vertical Alignment( "Default" ),
				TabPage1 << Visibility( "Visible" ),
				TabPage1 << Set Min Size( 241, 102 ),
				TabPage1 << Set Max Size( 30000, 30000 ),
				TabPage1 << Set Stretch( {"Neutre", "Neutre"} ),
				TabPage1 << Title( "Constructeur de graphiques" ),
				TabPage1 << Tip( "" ), TabPage1 << Icon( "Trellis" ),
				TabPage1 << Closeable( 1 ), TabPage1 << Moveable( 1 ),
				TabPage1 << Set Base Font( "Texte" ),
				TabPage1 << Set Font Scale( 1 ),
				Scroll1 << Background Color( 2147483647 ),
				Scroll1 << Border( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
				Scroll1 << Enabled( 1 ),
				Scroll1 << Horizontal Alignment( "Default" ),
				Scroll1 << Margin( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
				Scroll1 << Padding( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
				Scroll1 << Text Color( 2147483647 ), Scroll1 << UI Only( 0 ),
				Scroll1 << User Resizable( {1, 1} ),
				Scroll1 << Vertical Alignment( "Default" ),
				Scroll1 << Visibility( "Visible" ),
				Scroll1 << Set Min Size( 241, 76 ),
				Scroll1 << Set Max Size( 30141, 30001 ),
				Scroll1 << Set Stretch( {"Fenêtre", "Fenêtre"} ),
				Scroll1 << Width( 956 ), Scroll1 << Height( 702 ),
				Scroll1 << Set Auto Scrollable( 1 ),
				Scroll1 << Set Scrollers( 0, 0 ), Scroll1 << Set Show Empty( 0 ),
				Scroll1 << Set Clip Printing( 0 ),
				Report1 << Background Color( 2147483647 ),
				Report1 << Border( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
				Report1 << Enabled( 1 ),
				Report1 << Horizontal Alignment( "Default" ),
				Report1 << Margin( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
				Report1 << Padding( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
				Report1 << Text Color( 2147483647 ), Report1 << UI Only( 0 ),
				Report1 << Vertical Alignment( "Default" ),
				Report1 << Visibility( "Visible" ),
				Report1 << Set Min Size( 241, 76 ),
				Report1 << Set Max Size( 30141, 30001 ),
				Report1 << Set Stretch( {"Neutre", "Neutre"} ),
				Report1 << set horizontal( 0 ),
				TabPage2 << Background Color( 2147483647 ),
				TabPage2 << Border( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
				TabPage2 << Enabled( 1 ),
				TabPage2 << Horizontal Alignment( "Default" ),
				TabPage2 << Margin( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
				TabPage2 << Padding(
				), TabPage2 << Text Color( 2147483647 ), TabPage2 << UI Only( 0 ),
				TabPage2 << Vertical Alignment( "Default" ),
				TabPage2 << Visibility( "Visible" ),
				TabPage2 << Set Min Size( 198, 113 ),
				TabPage2 << Set Max Size( 30000, 30000 ),
				TabPage2 << Set Stretch( {"Neutre", "Neutre"} ),
				TabPage2 << Title( "Constructeur de graphiques" ),
				TabPage2 << Tip( "" ), TabPage2 << Icon( "Trellis" ),
				TabPage2 << Closeable( 1 ), TabPage2 << Moveable( 1 ),
				TabPage2 << Set Base Font( "Texte" ),
				TabPage2 << Set Font Scale( 1 ),
				Scroll2 << Background Color( 2147483647 ),
				Scroll2 << Border( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
				Scroll2 << Enabled( 1 ),
				Scroll2 << Horizontal Alignment( "Default" ),
				Scroll2 << Margin( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
				Scroll2 << Padding( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
				Scroll2 << Text Color( 2147483647 ), Scroll2 << UI Only( 0 ),
				Scroll2 << User Resizable( {1, 1} ),
				Scroll2 << Vertical Alignment( "Default" ),
				Scroll2 << Visibility( "Visible" ),
				Scroll2 << Set Min Size( 198, 87 ),
				Scroll2 << Set Max Size( 30098, 30001 ),
				Scroll2 << Set Stretch( {"Fenêtre", "Fenêtre"} ),
				Scroll2 << Width( 949 ), Scroll2 << Height( 702 ),
				Scroll2 << Set Auto Scrollable( 1 ),
				Scroll2 << Set Scrollers( 0, 0 ), Scroll2 << Set Show Empty( 0 ),
				Scroll2 << Set Clip Printing( 0 ),
				Report2 << Background Color( 2147483647 ),
				Report2 << Border( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
				Report2 << Enabled( 1 ),
				Report2 << Horizontal Alignment( "Default" ),
				Report2 << Margin( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
				Report2 << Padding( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
				Report2 << Text Color( 2147483647 ), Report2 << UI Only( 0 ),
				Report2 << Vertical Alignment( "Default" ),
				Report2 << Visibility( "Visible" ),
				Report2 << Set Min Size( 198, 87 ),
				Report2 << Set Max Size( 30098, 30001 ),
				Report2 << Set Stretch( {"Neutre", "Neutre"} ),
				Report2 << set horizontal( 0 )
	Initialize(
		Module1 << Auto Launch( 1 );
		Module1 << Set Module Type( "Report" );
		Module1 << Set Window Title( "^TABLENAME - ^APPNAME" );
) << Run
NokBoard = dash << Get Windows;
NokBoard << Save Picture ("D:\Project JMP\DashBoards\ProductionPercent-NokPercent_DashBoard_of_"||current_month||".png", "png");
Thank you in advance,
Best regards,
Yass
Yass
Re: PNG Export Issues for Dashboard in JMP 16
my bad, I forgot the ";" after Run.
) << Run ;
Are you getting the dashboard when you run the script?
Yass
Before, I didn't get the dashboard, but now I did find the issue.
Yass
Hi @jthi,
I have a question: I tried to change the line and bar colors in Graph Builder but I'm not sure how to do it. I created a dashboard you find the code in my last message where i have ask for help in the export Issues of the dashboard and attempted to modify it with code, but I haven't had any success.
Fill Color( "" ),
Line Color( "" ),
Do it interactively in JMP: right click on the legend and you should be able to change the colors and get the script from red triangle menu
Yass
Thank you.It works !!
Yass
) << Run ;
