Bonjour, je suis noovice sur JMP et j'aimerais comprendre Pourquoi JMP ne donne pas de p-value pour certaines distributions comme une loi normale d'ordre 2 ou 3?
Hi @kowa : Welcome to the community! I'm not sure what you are asking. Do you mean to ask why there is no Goodness-of-fit Test for the "Normal 2 Mixture Distribution" or "Normal 3 Mixture Distribution" in the Distribution platform?
Indeed when I have data adjustments that give me a lognormal distribution, I can have the P-value for Goodness-of-fit but jmp does not propose this if I have a normal distribution of order 2.
