kowa
P value
Bonjour, je suis noovice sur JMP et j'aimerais comprendre  Pourquoi JMP ne donne pas de p-value pour certaines distributions comme une loi normale d'ordre 2 ou 3?
Merci
MRB3855
Re: P value
Hi @kowa : Welcome to the community!  I'm not sure what you are asking. Do you mean to ask why there is no Goodness-of-fit Test for the "Normal 2 Mixture Distribution" or "Normal 3 Mixture Distribution" in the Distribution platform?
kowa
Re: P value
Hi @MRB3855 ,
yes, that's my question.
Indeed when I have data adjustments that give me a lognormal distribution, I can have the P-value for Goodness-of-fit but jmp does not propose this if I have a normal distribution of order 2.
MRB3855
Re: P value
Hi @kowa : JMP has no GOF test for these mixture models. And there are good reasons for this. See here:
https://community.jmp.com/t5/Discussions/Goodness-of-Fit/td-p/229235
For a more complex explanation/discussion/alternative see here:
https://www.sciencedirect.com/science/article/am/pii/S0167947318301142
And here:
https://www.martinmodrak.cz/2018/05/14/identifying-non-identifiability/#:~:text=What%20is%20%E2%80%9....
