ericx
Overlay with empty cell
I am using the graph builder and would like to overlay a column on my graph, however when I select the overlay, rows that are empty for that specific column I am overlaying disappears on the graph.  Is there a way to add an overlay for empty cells as well?
Thanks.
gzmorgan0
Re: Overlay with empty cell
@ericx,
You did not mention which version of JMP you are using. The picture below highlights the option Include Missing Categories. This example is Big Class, where column Sex2 is the same as sex with about 25% of the rows where no gender is specified.
Hope that helps.
Sorry, I'm a bit confused by your question.  If the cells are empty, then what do you want to appear? Empty cells have no content and therefore won't display anything.
ericx
Yes, empty cells have no content but I'd like to still be able to see them show up as a reference.
I could fill them in with "none" or something like that, but was wondering if there was I way I could avoid that.
gzmorgan0
@ericx,
Hope that helps.
ericx
Thanks, that's what I was looking for!
