karenb
Overlay normal quantile plots without long string labels
I am a longtime user of JMP7. To make overlay normal quantile plots I use Fit Y by X, where Y is the continual variable like Height and X is a categorical variable like Gender. Using Right-click/Legend gives a nice color coded legend for the curves, but JMP also tries to label each curve way up at the top (upper quantile) end of the curve. Invariably these are ugly and overlap each other. I havent discovered a way to turn them off. Any ideas? Is this fixed in JMP 8?
Thanks,
Karen
0 REPLIES 0
