djhanson
Overlay Line Chart - how to display datapoint labels on chart?
Is there a way (maybe ingenious) to display datapoint values on a Graph Builder overlay line chart?
Example, I do know if I set say dt1<<set label columns("N Things"); I can then get these datapoint labels for "N Things" column to show up on the chart as numbers, but only in a point chart.  I was trying to do this but for a line chart now but so far to no avail.  Thoughts?  DJ
ian_jmp
Level X
Re: Overlay Line Chart - how to display datapoint labels on chart?
Using persistent tooltips, you can do this kind of thing:
NamesDefaultToHere(1);
dt << Graph Builder(
			Size( 528, 452 ),
			Show Control Panel( 0 ),
			Variables(
				X( Transform Column( "Row", Formula( Row() ) ) ),
				Y( :height ),
				Overlay( :sex )
			Elements( Line( X, Y, Legend( 11 ) ) ),
				Dispatch(
					"Graph Builder",
					FrameBox,
					{Add Pin Annotation(
						Seg( Line Seg( 2 ) ),
						Index( 3 ),
						Index Row( 11 ),
						UniqueID( 84806150 ),
						FoundPt( {187, 183} ),
						Origin( {12.1797520661157, 64.8846153846154} ),
						Offset( {-9, -63} ),
						Tag Line,
						Font( "Helvetica Neue", 11, "Plain" )
					), Add Pin Annotation(
						Seg( Line Seg( 1 ) ),
						Index( 13 ),
						Index Row( 27 ),
						UniqueID( 84567066 ),
						FoundPt( {355, 230} ),
						Origin( {27.7995867768595, 62.1730769230769} ),
						Offset( {-34, 86} ),
						Tag Line,
I imagine one could do this through JSL, rather than 'by hand'.
You can cheat by creating a points chart with the same summary statistic as your desired line chart. Then hold down shift and click the line chart.
To hide the markers, set them to be a space character (Alt 255). To do this select all the rows in the data table. From the rows hotspot select Markers - Other... Click in the text box that appears then hold down the Alt key and type 255. Hit OK.
Now any rows you label will appear on the line in the correct place.
ian_jmp
Level X
			Size( 528, 452 ),
			Variables(
				Y( :height ),
				Overlay( :sex )
				Dispatch(
					"Graph Builder",
					FrameBox,
						Index( 3 ),
						Index Row( 11 ),
						Tag Line,
						Index( 13 ),
						Index Row( 27 ),
						Tag Line,
