NeF
NeF
Outliers more than 3 standard deviations in JMP
Is there any way to detect outliers more than 3 stansard deviations in JMP?
I should say that I am familiar with the "explore outliers option as well as "Levey Jennings" Control chart. but, is there other way to detect outliers more than 3SDs?
thanks,
Ne
6 REPLIES 6
Thomas1
Level V
Re: Outliers more than 3 standard deviations in JMP
@NeF wrote:
thanks,
Ne
This can be solved by creating a new formula column with the formula:
If( :Data > Col Mean( :Data ) + Col Std Dev( :Data ) * 3,
    1,
    0
The data column is your source column.
In case you want the vaules > 3SDs, the formula is:
    :Data,
NeF
NeF
Dear Thomas1,
Thank you for your kind reply!
Ne
Thomas1
Level V
My second formula, which should show the values > 3 SDs contains an error.  Therefore it doesn’t work. You have to replace "*" against *
So the correct formula, in order to get the values, is:
    :Data,
NeF
NeF
hi,
thanks a lot. I've noticed that while using it yesterday.
best,
Ne
gzmorgan0
Just a simple addendum to @Thomas1 response. If you have severe outlier, the Col Std Dev can be pretty large and can bias the mean.
An alternative is to use the median + k* pseudo sigma for the upper screening limit and median - k* pseudo sigma fro the lower screening limit.
Here is a the column fomula for a column named weight. For raw data, sometimes quantiles 0.85 and 0.15 are used to compute the pseudo sigma with 6 as the multiplier for ps.
Local( {ps},
	ps = (Col Quantile( :weight, 0.75 ) - Col Quantile( :weight, 0.25 )) / 1.349;
	If(
		:weight > Col Quantile( :weight, 0.5 ) + 5 * ps, 1,
		:weight < Col Quantile( :weight, 0.5 ) - 5 * ps, -1,
		0
If you are scripting, the Distribution platform computes a Robust Mean and Robust Std Dev.  Here is a simple script to get these values.
dt = Open( "$sample_data/Big class.jmp");
dist = dt << Distribution(
	Continuous Distribution(
		Column( :height ),
		Quantiles( 0 ),
		Horizontal Layout( 1 ),
		Histogram( 0 ),
		Vertical( 0 ),
		Outlier Box Plot( 0 ),
		Customize Summary Statistics(
			Trimmed Mean( 1 ),
			Robust Mean( 1 ),
			Robust Std Dev( 1 ),
			Set Alpha Level( 0.05 )
snames = report(dist)["Summary Statistics"][TableBox(1)][StringColBox(1)] << get;
svalues= report(dist)["Summary Statistics"][TableBox(1)][NumberColBox(1)] << get;
stats = Associative Array(snames, svalues);  //cretea a keyed list
r_xb = stats["Robust Mean"];
r_sd = stats["Robust Standard Deviation"];
show(r_xb, r_sd);
//now use r_xb + <4|5|6> * r_sd  and  r_xb - <4|5|6> * r_sd for screening limits
NeF
NeF
Hi gzmorgan0,
Its really helpful!
thanks,
Nehai
