  • Due to inclement weather, JMP support response times may be slower than usual during the week of January 26.
    To submit a request for support, please send email to support@jmp.com.
    We appreciate your patience at this time.
Assaf1
Open several JMP files in one session
When I open JMP file from file explorer (not from JMP itself), it's open separately using new JMP window/session and not from the opened session.
Also, when I open several JMP files - each file open in separate session...
How can I fix it to open all files in the existing session?
Thanks a lot!
Assaf
Assaf1
Re: Open several JMP files in one session
Solution exist in the follows:
http://www.jmp.com/support/notes/52/261.html
Thanks again!
Assaf
dale_lehman
Open JMP first and then open whatever files you want from within that JMP window.  That way you can manipulate the files (e.g., join them).  In other words, do not click on the files to open them with JMP - just reverse the order.
Go to
     File==>Preferences==>Windows Specific
Then click on the button at the lower part of the window, named "Reset Associations"
That should fix the issue
Assaf1
Thanks for your efforts
But "Reset Associations" not fixed it...
Assaf1
Thanks again!
Assaf
