UserID16644
Level V
Open files using contains ()
Hi all,
I am try to create a script that would go through directories to find the input file. However, some file names may have different characters.
For example:
My input in favorite fruit would be: Orange
Existing files from folder would be: Mark_Orange_Mango.jmp, Jane_Apple.jmp, John_Orange.jmp
Files that would open: Mark_Orange_Mango.jmp and John_Orange.jmp
How can I open these files using contains() or what function do I need to use? I am using JMP 15
Here is the piece of code I am working on:
nw = New Window( "Favorite Fruits", << modal(),
	lineupbox(ncol(2), spacing(5),
		Text Box( "Name:" ),
		teb1 = Text Edit Box( "", <<set width( 150 ) ),
		Text Box( "Age:" ),
		teb2 = Text Edit Box( "", <<set width( 150 ) ),
		Text Box( "Birthday:" ),
		teb3 = Text Edit Box( "", <<set width( 150 ) ),
		Text Box( "Favorite Fruit:" ),
		teb4 = Text Edit Box( "", <<set width( 150 ) ),
	Button Box( "OK",
		name = teb1 << get text ();
		age = teb2 << get text ();
		bday = teb3 << get text ();
		fruit = teb4 << get text ();
/* ----- opening the files ----- */
path = "C:\Users\Desktop" || Char (name) || "\" || Char (bday);
files = Files in Directory (path);
For (j=1, j<= N Items (files), j++,
	If (Contains (fruit[j], ".jmp"), // Open file that contains the input from text box
Re: Open files using contains ()
See if this works for you
	<<modal(),
	Lineup Box( N Col( 2 ), spacing( 5 ),
		Text Box( "Age:" ),
	Button Box( "OK",
		name = teb1 << get text();
		age = teb2 << get text();
		bday = teb3 << get text();
		fruit = teb4 << get text();
path = "C:\Users\Desktop" || Char( name ) || "\" || Char( bday );
files = Files In Directory();
For( i = N Items( files ), i >= 1, i--,
	If( Word( -1, files[i], "." ) != "jmp",
		Remove From( files, i, 1 )
If( N Items( Files ) > 0,
	tableList = {};
	For( j = 1, j <= N Items( files ), j++,
		If( Contains( files[j], fruit ) > 0, // Open file that contains the input from text box
			dd = Open( path || "/" || files[j] );
			Insert Into( tableList, dd );
	<<modal(),
		Text Box( "Age:" ),
	Button Box( "OK",
	tableList = {};
UserID16644
Level V
Hi, it is working, however, is it possible to have multiple conditions on my contain() function?
It can be as complex as you want it to be
If(
(Contains( files[j], fruit ) & Contains( files[j], "Good Luck" )) |
Contains( files[j], "Special" ),
I strongly suggest you take some time to read the Scripting Guide.  It will make your journey into scripting far more pleasent.
