twillkickers
Only select rows where the first character of the contained string is a number, not a letter
How can I use JSL to only select rows that contain a string that begins with a number, while ignoring strings that begin with a letter?
ms
Super User (Alumni) ms
Re: Only select rows where the first character of the contained string is a number, not a letter
There are several ways to do this. Here are two examples.
dt << select where(!Is Missing(Num(Left(:data[], 1))));
dt << select where(!Is Missing(Regex(Left(:data[], 1), "^\d")));
ms
