Due to the recently reported Microsoft outage, users may be temporarily unable to access My JMP or experience a delay receiving their verification codes. If you have previously installed JMP on your computer, this outage should not impact your ability to access the software. My JMP services will be restored as soon as Microsoft resolves this issue.
Only get files and not sub-directories with Files In Directory( )
Jul 23, 2026 10:26 AM(476 views)
Is there a simple way to use Files In Directory( ) to only get files and not sub-directories in a specified directory.
I guess one approach would be to use the recursive(1) option, and then filter out from the list the strings that have a "/" in them, but seems there aught to be a simpler way.
If I remember correctly I have just gotten the list with Files In Directory and then used Filter Each to get the list of files. You could also use command line or multiple file import (Directory Tree: Explore Space Used by Folders )
On win there are several non-file types of objects that could show up if you are poking around in odd places. Using the isFile and isDirectory functions helps.
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '961054' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '961054') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '961054') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
