DownloadSemiconductor Toolkit: Tools to create wafer maps, add wafer geometry to graphics, explore die defects & compare wafers.
Discovery Summit 2026: Early User Edition - September 23-24.Register. It's free.
Use JMP Clinical with CDISC-compliant data. Review studies, ID safety and efficacy signals & communicate findings with interactive graphics. Register to see how. Aug. 27, 2 pm US ET.
Only get files and not sub-directories with Files In Directory( )
4 weeks ago(149 views)
Is there a simple way to use Files In Directory( ) to only get files and not sub-directories in a specified directory.
I guess one approach would be to use the recursive(1) option, and then filter out from the list the strings that have a "/" in them, but seems there aught to be a simpler way.
If I remember correctly I have just gotten the list with Files In Directory and then used Filter Each to get the list of files. You could also use command line or multiple file import (Directory Tree: Explore Space Used by Folders )
On win there are several non-file types of objects that could show up if you are poking around in odd places. Using the isFile and isDirectory functions helps.
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '961054' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '961054') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '961054') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
