ms
Super User (Alumni) ms
Number of selected rows
In the lower left pane of a JMP data table there is a list with row information, including the number of currently selected cells.
Is there a JSL command that can retrieve that information directly? I can of course loop through all rows and count all selected cells. However, it may be more efficient to grab a number that JMP already seem to have calculated automatically.
I am asking because I am running a script that conditionally selects different sets of rows in a huge table and want a fast way to neglect sets with too few rows.
pmroz
Re: Number of selected rows
num_selected = nrows(dt << get selected rows);
pmroz
ms
Thanks! Just what I was looking for. Simple and elegant.
robust1972
hi, PMroz
I am trying to select certain rows in a table with a criteria and then delete them if the number of selected rows is greater than 0 as below but got the error as inserted pic.
if( (nrows(dtlist8<< get selected rows()))>0,
dtlist8 <<delete rows,
pmroz
What is dtlist8 pointing to?  It seems like it isn't pointing to a table.  The following code works:
dtlist8 = open("$sample_data\Big Class.jmp");
if( nrows(dtlist8 << get selected rows()) > 0,
      dtlist8 << delete rows,
