BobL
Not able to replace text in a graph hover label any one have a solution?
Does any one face the same issue as mine ? After selecting replace text in a hover label and changing the text and click ok, the final label text was not changed at all. Any options to troubleshoot?
ian_jmp
Level X
Re: Not able to replace text in a graph hover label any one have a solution?
Depending on what your issue actually is, this may not offer a solution as such: But (if you are unaware) there's plenty of instruction here.
nascif_jmp
This was a defect introduced in JMP 15. You can achieve the same behavior using gridlets, as described in the documentation pointed to by @ian_jmp (thanks).
This defect has been fixed in JMP 16, but the preferred method for modifying content in Hover Labels going forward is to use gridlets.
ezorlo
This method is complicated and not good for me.
How can I receive a patch/update for JMP Pro 15?
jmv
jmv
I have this same issue with jmp 15, has anyone identified a fix?
