statslearner
Normalizing the Idata in second data sheet using Data in first Data sheet
Hi
This is regarding normalizing one dataset and applying the same normalization to other dataset.
Either i apply z score or min-max on one dataset or z score standardization. After normalizing the first dataset, I apply the same formulas to the second dataset using Excel's cell referencing and fill handle.
here are the two JMP datasets for example. How can i do this in JMP?
please help
Thanks
Re: Normalizing the Idata in second data sheet using Data in first Data sheet
You can turn the recording on for a workflow as you normalize the first data table, and then simply run the workflow on the second data table.
If this does not meet your needs, please provide more specifics and I am sure the Community will be able to help you.
