Gabriel
Non-linear fit (Exponential regression)
Hi everyone, Good day,
I have been having a hard time fitting an exponential regression graph. I have attached what I want as gotten from Excel, but I see I am unable to get it done on Jmp.
I hope I would be able to do it on graph builder do I can at least show the exponential regressions based on the factors (treatment). First, I want to be able to fit an exponential regression on Jmp, not using formula as I have seen in previous post (it doesn't give what I see in the attached).
Please help.
Gabriel Mulero
Jemster
Re: Non-linear fit (Exponential regression)
You could try looking under analyze>specialized modelling>fit curve. The red triangle menu for the graph should let you fit exponential models
dale_lehman
Try Fit Y by X and then Fit Special.  Use the exponential transformation for X.
Gabriel
Thank you Dale, I tried it but it gives nothing close to the values in excel like if you do a linear regression in excel and then do it in Jmp, we as expected get same thing.
- the trendline is nothing close, the R2 is also nothing close.
I appreciate the assistance because I never tried what you showed before.
Gabriel Mulero
It would be much easier to assist if you provide the data table.  Then we would have some context and possibly could add a script to the table that creates the plot you are looking for.
Jemster
