Hi !
I understand better your situation.
Concerning the second point, if you launch the "Fit model" platform with a Standard Least Square personality, you will have a regresssion graph showing for each category (Major/Minor) the regression line (see photo below/attached).
You can also have a look on how significant are main effects and interaction on the "Effect Summary" in order to take into account (or not) the interaction in your analysis. You can also use the Graph Builder in order to see emotional response in function of your inputs, and showing details about regression coefficient in order to help you.
Finally, if you think it may be good to have a look at several parameters in order to see differences in case of interaction, I would give a try to the "Variability / Attribute Gauge chart" in "Analyze", then "Quality and Process". You could be able to see if several parameter seems to influence the response in a particular way. You can do it directly, or create a "class" column (categorical) for your continuous input tempo in order to group similar tempo by categorical groups.
I think from what I see I'm out of other options, but by combining these ideas, you may be able to have a clear view on your topic :)
Victor GUILLER
Scientific Expertise Engineer
L'Oréal - Data & Analytics
