mnf
mnf
Newline character
I would like to simply insert a newline character at the end of each item in an array, being written to file.  Does JMP not recognize '\n'?  If so how would I get it to output
file1
file2
file3
rather than
file1\nfile2\nfile3
for(i=1,i<=length(Files),i++,
	filestring=filestring|| " " || char(Files[i]) || "\n");
f=Save Text File(pypath || "argfile.txt",filestring,mode("replace"));
Re: Newline character
The complete list of Escape Characters can be found in the Scripting Guide
     Help==>Books==>Scripting Guide
For your need, \!n is the escape character sequence
mnf
mnf
Is there any (logical) reason why it is not simply \n, as in many other languages?
I am not aware of why JMP implemented a 2 character escape sequence.  Maybe to help with double byte characters.  Maybe someone at JMP may have the logic of their decision.
