tsnow_
New cut off point and ROC curve- Add-in
Good day.
Kindly assist.
I have changed the cut-off point and I need to generate a new ROC curve. I have installed an Add-in but does not have the 'target level' option which I believe is important.
Kindly assist me with an alternative way of doing this. I have attached the file.
Thanks
KarenC
Re: New cut off point and ROC curve- Add-in
What version of JMP are you using?  The target option should appear in the add-in...
KarenC
tsnow_
Thanks, I need to get an update.
