jy06115197
New Column Set Value Help
I know the following script is incorrect:
a = {"a", "b", "b"};
b = [1, 2, 3];
c = [4, 5, 6];
New Table( "SQL Results",
    New Column( "a", character, set values( a ) ),
    New Column( "b", formula( If( :a == "a", set values( b ), set values( c ) ) ) )
How do I change it to make the output:
 a      1
 b      5
 b      6
so the first row checks if column 1 is "a",  yes then use b[1]; second-row checks if column 1 is "a", no then use c[2]; third-row checks if column 1 is "a", no then use c[3].
Thank you!
Re: New Column Set Value Help
Here is how to do what you want.  Please note that JMP had an issue in the formula with the matrix b reference, since the formula was being interpreted as referencing the column b.  That is why I changed the column name to b2.
b = [1, 2, 3];
c = [4, 5, 6];
dt = New Table( "SQL Results",
dt << New Column( "b2",
	formula(
		If( :a == "a",
			b[Row()],
			c[Row()]
To illustrate the scoping issue further, if you really need  the column to be named  "b" then one can specify the fully scoped name of here:b (the "here" comes from Names Default to Here( 1 ) )
b = [1, 2, 3];
c = [4, 5, 6];
dt << New Column( "b",
	formula(
		If( :a == "a",
			here:b[Row()],
			c[Row()]
b = [1, 2, 3];
c = [4, 5, 6];
	formula(
		If( :a == "a",
			b[Row()],
			c[Row()]
b = [1, 2, 3];
c = [4, 5, 6];
	formula(
		If( :a == "a",
			here:b[Row()],
			c[Row()]
jy06115197
Nelson,
Thank you so much. I truly appreciate your help.
