yanee
New Column : Set Initial Value from List Data
Hi
The script will read numeric column name from the file. If there is only 1 column, I want to create the new column and assign value in the column with the header reading from file.  In below case, the new column should have initial value = ITH
I use below script but it doesn't assign the initial value. Not sure why.
ColList2 = Data Table( "raw data" ) << get column names( numeric );
if(n items (ColList2) ==1,
	new column("Label",character, nominal,set each value (ColList2));
Thierry_S
Re: New Column : Set Initial Value from List Data
There was just one piece missing from the solution: you need to specify the format of the content for ColList2 when using the Get Column Names command (see below)
Names default to Here (1);
dt = Current Data table ();
ColList2 = dt << get column names( numeric, string );
	dt << new column("TEST", character);
	dt:TEST << set each value (ColList2 [1])
Thierry R. Sornasse
ColList2 is a list, so you need to indicate which element of the list you want to use when you "set each value".  Since there is only 1 item in the list, you would specify it as
colList2[1]
	new column("Label",character, nominal,set each value (ColList2[1]));
yanee
try that but it didn't work. Below is error message.
Ah, I missed the point, that when you get the column names, your are returning them as expressions, not as character strings.  Therefore, change the line of code to:
new column("Label",character, nominal,set each value (char(ColList2[1])));
Thierry_S
Thierry R. Sornasse
