JanneI
Nested loops with List boxes
I am trying to construct a 2D-matrix with 2 nested FOR-loops used in the mouse over hover labels (Graph builder -> Hover Label Editor -> Graphlet).
I provide here a simplified example for 2*2 matrix.
hlb  = H List Box();
vlb  = V List Box();
For (row=1, row<=2, row++,
	For (col=1, col<=2, col++,
		hlb << append(Text Box("Row: "|| char(row) ||", Col: "|| char(col) ))
	vlb << append(hlb);
vlb << get picture;
Script above results to wrong output:
To get correct outcome, I need somehow reset the H List Box. However, if I add hlb << Set Items({}); like below, the outcome is very same as above (ie. not correct).
hlb  = H List Box();
vlb  = V List Box();
	vlb << append(hlb);
vlb << get picture;
I also tried to delete and recreate the H List Box as below. This does not work either as it deletes the H List Box object already fed in to V List Box
hlb  = H List Box();
vlb  = V List Box();
	vlb << append(hlb);
	hlb << Delete;
	hlb  = H List Box();
vlb << get picture;
Any further advices? My JMP version is 16.2
Thanks;
Janne
Re: Nested loops with List boxes
I believe this is what you want
vlb = V List Box();
For( row = 1, row <= 2, row++,
	hlb = H List Box();
	For( col = 1, col <= 2, col++,
		hlb << append( Text Box( "Row: " || Char( row ) || ", Col: " || Char( col ) ) )
	vlb << append( hlb );
New Window( "show", vlb << get picture );
vlb = V List Box();
	hlb = H List Box();
You could also use Table Box or Lineup Box with N Col:
vlb = V List Box();
For(row = 1, row <= 2, row++,
	hlb = H List Box();
	For(col = 1, col <= 2, col++,
		hlb << append(Text Box("Row: " || Char(row) || ", Col: " || Char(col) || " || "))
	vlb << append(hlb);
lb = Lineup Box(N Col(2));
cols = 2;
rows = 2;
For(i = 1, i <= cols * rows, i++,
	row = Ceiling(i / 2);
	col = !Modulo(i, 2) + 1; //just some calculation which works in this case
	Show(col);
	lb << append(Text Box("Row: " || Char(row) || ", Col: " || Char(col) || " || "));
//one option
tb = Table Box("",
	String Col Box("row1", {"Row: 1", "Row: 2"}),
	String Col Box("col1", {"Col: 1", "Col: 1"}),
	String Col Box("col1", {"Col: 2", "Col: 2"}),
New Window("",
	Lineup Box(N Col(1),
		Text Box("V List Box"),
		vlb,
		Text Box("Lineup"),
		lb,
		Text Box("Table Box"),
		tb
JanneI
Jim: Thanks for your solution. It works well. I see now why my trials were not successful.
Jarmo: Thanks for your suggestion for alternative solution to use Table Box or Lineup Box; very educative.
Janne
I wonder if a Line Up Box would be a better approach?
