bbenny7
Nested Try statement
I am trying to run a script similar to the following:
Try(
       dt1 = Open(path1);
       Try(
               dt2 = Open(path2);
               dt2 << Concatenate(dt1, "Append to first table");
              dt2 = dt1 << Subset(All rows);
       dt2 << Save(path2);
       print("No dt1 found!");
But, when it fails to open dt2, instead of executing the subset statement, it executes the print statement.
The question is if it possible to run nested try statements.
bbenny7
Re: Nested Try statement
I have found an error in catch expression of the second try statement, that is why it was executing the print statement.
After correction, the script works as intended.
bbenny7
