sciguy
Nested Recode
Is there a way to nest a Recode on a single column based on multiple columns using JSL?
dt << New Column( "Stature",
		Character( 40 ),
		"Nominal",
		Formula(
			Recode(
				:age & :height,
				{Map Value(
					_rcOrig, {
					"12" & "59", "short tween",
					"12" & "66", "Tall tween",
					"17" & "70", "Tall teenager"
					Unmatched( empty() )
	Set Display Width( 56 )
Re: Nested Recode
I am not aware of the Recode having the capability you are asking about, however it is easily handled in an If() function
	Character( 40 ),
	"Nominal",
	Formula(
		If(
			:age == 12 & :Height == 59, "short tween",
			:age == 12 & :height == 66, "Tall tween",
			:age == 17 & :height == 70, "Tall teenager",
Re: Nested Recode
	Character( 40 ),
	"Nominal",
	Formula(
		If(
sciguy
Re: Nested Recode
This worked perfectly. Should have gone with an if() function to begin with. Thank you.
