ausername
Nested/Multiple Data Filter Context Box
 ::edit:: Added a comment in the code and included a screenshot to help visualize.
Is it possible to do nested filter context boxes or to generate something that effectively does the same thing? Basically I want a set of parent filters that apply to all plots in a report. The reports within that plot need their own particular filters to limit the data they display.
I have an interactive report layed like this:
(1) An H List box divided into two columns.
    (A) The first column contains a set of filters that apply to anything in the second column.
    (B) The second column contains a tab box with multiple tabs for different "tool types."
         (i) Each tab contains an h list box with a column of variabiity charts for each "tool" of a given type. Each column needs its own filter to limit which "tool" it displays.
              (a) This filter is hard coded based on a list, but the VarCharts need to update based on the filters in (A).
What I am finding is that if I put a where() within the variability chart, it ignores the filters in (A). I then tried nesting filter context boxes, but this doesn't seem to work. The new filters show up, but only the parent-most filter actually does anything.
I attempted to create a stripped-down/anonymized version of my code, so there may be some typos:
myRootPath = "C:\Log_Testing\";
myLogPath = myRootPath;
myReportPath = myRootPath || "Report\";
mypath = myRootPath || "Logs\";
// I tools to plot
// format: ToolID
iTools = {"i1", "i5"};
// P tools to plot
// format: ToolID
pTools = {"p1", "p2"};
Set Current Directory( mypath );
mainDt = Open( myLogPath || "Log.jmp" );
Batch Interactive( 1 );  //Batch mode
dt_name = mainDt << get name();
dt_path = myLogPath;
mainDt << Clear Select;
filterContextBox = Data Filter Context Box();
spcWin = New Window( dt_name || "_VarCharts", filterContextBox );
filterBox = H List Box(
	mainDt << Data Filter(
			//Conditional,
		Local,
		Add Filter(
			columns( :WW, :D ),
			Display( :WW, Blocks Display ),
			Display( :D, Blocks Display ),
		Mode( Select( 0 ), Show( 1 ), Include( 1 ) ),
filterContextBox << Append( filterbox );
filterBox << Append( tb = Tab Box() );
tb << Add( "P", hPTab = H List Box() );
tb << Add( "I", hITab = H List Box() );
numPTools = N Items( pTools );
numITools = N Items( iTools );
//Create P Plots
For( j = 1, j <= numPTools, j++,
	hPTab << Append( vToolBox = V List Box() );
	vToolBox << Append( toolTab = Outline Box( pTools[j] ) );
	ycol = "VariableName";
	parseName = "Variability Chart for " || ycol;
	toolTab << append(
		NewChart = Variability Chart(
			Y( Column( ycol ) ),
			X( :WW, :D ),
			Max Iter( 100 ),
			Conv Limit( 0.00000001 ),
			Number Integration Abscissas( 128 ),
			Number Function Evals( 65536 ),
			Analysis Type( Name( "Choose best analysis (EMS REML Bayesian)" ) ),
			Connect Cell Means( 1 ),
			Std Dev Chart( 0 ),
			Points Jittered( 0 ),
			AIAG Labels( 0 ),
			Automatic Recalc( 1 ),
/*If the next line isn't commented out, it ignores the local filter and only uses this one. I need both. */
Where( :ToolID == pTools[j] ); SendToReport( Dispatch( {}, "Variability Gauge", OutlineBox, {Set Title( "" )} ), Dispatch( {parseName}, "2", ScaleBox( 2 ), {Format( "Fixed Dec", 4, 0 ), Min( 0 )} ), Dispatch( {parseName}, "Group Means", StringColBox, {Visibility( "Collapse" )} ), Dispatch( {parseName}, "", PlotColBox, {Visibility( "Collapse" )} ) ) ) ); );
11 REPLIES 11
ausername
Re: Nested/Multiple Data Filter Context Box
This appears to be exactly what I'm looking for! Thanks so much! So it looks like my mistake was using source boxes at all?
In Jim's examples, the Data Filter Source Box is exactly what is needed to use one JMP graph to filter another.  I did not see a Data Filter Source Box in your original script - I think the main issue was the use of the Where() clause (subset table) with a filter on the parent table.
The Data Filter Source Box is only need to use a platform as a filter, because unlike the built-in Data Filter object we cannot infer what the filter behavior should be.
