Need to populate no of unique entery
I need to populate no of unique entries in a new column if Flagged="Yes". When I use Col N Unique formula I get Different count if Flagged="No".
mmarchandFSLR
Re: Need to populate no of unique entery
I don't have JMP 19, so no Col N Unique(), but I think this gets you what you want.  As Constant() makes the evaluation much faster.
As Constant( Length( Associative Array( :SN[Where( :Flagged == "Yes" )] ) << Get Keys ) )
Current Data Table() << NEW COLUMN("A", Numeric, Formula(
	Col Sum(If(:Column 2 == "y" & Row() == Col Min(Row(), :Column 1), 1, 0))
I don't use JMP19 so I'm not that familiar with Col N Unique but maybe something like this
	Col Max(If(:Column 2 == "y", Col N Unique(:Column 1, :Column 2), .))
Column 1 is SN and Column 2 is flagged
8 REPLIES 8
You are using Flagged == "Yes" as grouping "column" so it will calculate separate unique values for Yes and No.
Any suggestion for how to populate Yes calculation in entire column?
mmarchandFSLR
hogi
Level XIII
The Col N unique() function is so helpful!
It makes many analyses much easier.
I hope,
will work in JMP 19.x.
Looks straight forward- but at the moment this doesn't work
-  unfortunately, Col N Unique() behaved different to the other col ... aggregations:
[from  Tiny Traps in Jmp and JSL ].
hogi
Level XIII
Other details you should be aware of:
Col score & Col N unique
txnelson edit: This is not a solution.  See @hogi  answer below.
Here is how I would do it:
Current Data Table() << New Column( "A",
	Numeric,
	Formula(
		As Constant(
			theCount = N Rows(
				get rows where( :column 2 == "y" )
		theCount;
hogi
Level XIII
JMP 18:
New Column( "unique",
	Formula(
		As Constant(
			Length(
JMP19:
dt << New Column( "unique",
	Formula(
		Col Max(
			If( :Column 2 == "y",
				Col N Unique( :Column 1, :Column 2 ),
JMP 19.x:
dt << new column("unique",
   Formula( Col N Unique(If(:Flagged == "y",:SN, .) )
JMP20?
Formula( Col N Unique(:SN, Where(:Flagged) )
The last one is my favorite - it will facilitate certain types of data analysis a lot!
please vote: Col Median (and others): add "Where" option
otherwise we have to wait for v25 ...
