Ghosted
Need help with modeling
I have a 2 part mixture model with 1 process variable and i need help analyzing it please. See attached:
FM% and SM% are 2 parts that = 100%
The process variable is Combined GT
Response is Gloss 60
Any help is greatly appreciated, is there any association here?
Re: Need help with modeling
I will help you, but this experiment is not a JMP data table and it was not designed with JMP as far as I can tell.
I imported the spreadsheet into a JMP data table. I converted the percentages ( 0-100 ) to proportions ( 0-1 ). I added the necessary column properties to the factors. Then I gave up. I made the design with JMP Custom Design and copied your values over. I can now fit the model. The two-level components support only the pure blend estimates.
What have you done or tried on your own so far? What difficulty were you having?
