lehaofeng
Level V
Need Help: Fit Model Window and Report Window in Listboxes
I have a problem: I want to put the "fit model" window to a listbox, when user presses the run button, I can put the report window to another listbox. But the report window doesn't go to the listbox automatically when I press the run button , how to resolve it?
6 REPLIES 6
Byron_JMP
Re: Need Help: Fit Model Window and Report Window in Listboxes
I'm not quite sure if I understand what you're asking, could you post an example of what you're trying to do?
lehaofeng
Level V
Thank you! This is my script:
Tab Box(
	"setting",
	V List Box(
		H List Box( align( center ), Button Box( "select datatable" ), Spacer Box( size( 5, 1 ) ), fit_tb1 = Text Box( "raw data.jmp" ) ),
		dlg = dt1 << fit model( Y(  ), Effects(  ),
		<<keep dialog open( 1 ) )
	"report",
	V List Box(
		【 put dlg(fit model) run results to here! but how? 】
lehaofeng
Level V
TKS, I have tried it , but it didn't work.
The problem is that when I press the run button(in fit model platform), the report window cannot be controlled well and is not easy to reference.
You might have to capture the script on trigger, close the report window and then rerun and add it to the vlb.
lehaofeng
Level V
Yes, I am currently stuck at the step of capturing the script. I don’t know how to automatically capture the script for the report window when it triggers.
