LaserGuy
Nearest Neighbor Algorithm: Need Optimization Help
Hi Everyone,
I have created the following script. It is meant to analyze a data table where each row corresponds to a chip in a wafer, and each row has a coordinate (x,y) and some parameters. The script will go through each row, look for other rows that correspond to dies that are "neighbors" to this die, and calculate the median and standard deviation of some parameter for that neighborhood.
The issue here is that it while it works, it takes a long time to run when analyzing data sets with a tens of thousands of rows.
I would really appreciate it if anyone can give pointers on how to optimize the script to reduce the computation time.
Code Below:
dt0 = current data table();
	dt0 << new column("NN_median");
	dt0 << new column("NN_stdev");
for ( i = 1, i <= N Rows(dt0), i++,
	//Find rows corresponding to neighboring dies
	m = dt0[0,{"x", "y"}];
	v = ( abs( m[0,1] - :x[i] ) <= 2 )
		( abs( m[0,2] - :y[i] ) <= 2 );
	rows = loc(v);
	// Create new DT of neighborhood
	dt1 = dt0 << subset( Rows(rows), Columns(:param), invisible );
	//Calculate Median and Std Dev
	tb = Tabulate(
		Add Table(
			Column Table( Statistics( Median, Std Dev ) ),
			Row Table( Analysis Columns( column("param") ) )
	dt2 = tb << make into data table( invisible );
	tb << close window;
	current data table(dt2);
	placeholder_median = :Median[1];
	placeholder_stdev = :Std Dev[1];
	close(dt2, no save);
	close(dt1, no save);
	current data table(dt0);
	:NN_median[i] = placeholder_median;
	:NN_stdev[i] = placeholder_stdev;
Re: Nearest Neighbor Algorithm: Need Optimization Help
I obtained the identical results in 11 seconds using
dt0 = Current Data Table();
dt0 << New Column( "NN_median" );
dt0 << New Column( "NN_stdev" );
m = dt0[0, {"x", "y"}];
For( i = 1, i <= N Rows( dt0 ), i++,
	v = (Abs( m[0, 1] - :x[i] ) <= 2) & (Abs( m[0, 2] - :y[i] ) <= 2);
	rows = Loc( v );
	dt0:NN_stdev[i] = Std Dev( dt0:param[rows] );
	dt0:NN_median[i] = Quantile( .5, dt0:param[rows] );
while your code too over 13 minutes
	rows = Loc( v );
ian_jmp
Level X
I didn't do any benchmarking, but might expect that using 'KDTable()' would be good for larger, more general problems:
n = 100;		// Size of square
// Make a table of x and y locations
dtx = AsTable((1::n)`, << Invisible);
dty = AsTable((1::n)`, << Invisible);
dt = dty << Join( With( dtx ), Cartesian Join );
Close(dtx, NoSave);
Close(dty, NoSave);
Column(dt, 1) << setName("x");
Column(dt, 2) << setName("y");
dt << deleteProperty("Source");
dt << setName("xy Locations");
// Put these locations into a matrix
mat = dt << getAsMatrix;
tbl = KDTable( mat );
// Pick a point in the interior, so we don't need to decide on any boundary conditions
myX = RandomInteger(2, n-1);
myY = RandomInteger(2, n-1);
myRow = Loc(mat[0, 1] == myX & mat[0, 2] == myY);
myRow = myRow[1];
// Find the 8 nearest neighbours to the chosen point
{rows, dist} = tbl << K nearest rows( 8, myRow );
Show( myRow, rows );
// Check it worked
myXvals = Column(dt, "x")[myRow];
myYvals = Column(dt, "y")[myRow];
dt << NewColumn("Distance", Numeric, Continuous, Formula(sqrt((:x - myXvals)^2 +(:y - myYvals)^2)));
dt << selectRows(VConcat(myRow, rows`));
gb = dt << Graph Builder(
						Size( 529, 453 ),
						Variables( X( :x ), Y( :y ), Color( :Distance ) ),
						Elements( Points( X, Y, Legend( 5 ) ) )
LaserGuy
Thanks! I am learning JMP script syntaxes as I go along. Your code certainly bypasses quite a few unnecessary operations.
Level XIII
Let's take the sample data set *)  and do some benchmarking
- let's start with an example how you should NOT do it ...
*) actual use cases are ~ 500 x 500 dies and hundreds of wafers.
dt0 = Open( "$SAMPLE_DATA/Wafer Stacked.jmp" );
wait(0);
t0 = hptime();
dt0 << New Column( "row", set each value( Row() ) );
max dist = 1; // just keep the direct neighbors
// create a lookup table
dtx = As Table( (-21 :: 21)`, <<Invisible );
dty = As Table( (-21 :: 21)`, <<Invisible );
dtLookup = dty << Join( With( dtx ), Cartesian Join, Output Table( "xyLocations" ) );
Close( dtx, NoSave );
Close( dty, NoSave );
Column( dtLookup, 1 ) << setName( "x" );
Column( dtLookup, 2 ) << setName( "y" );
// create the KDTable
mat = dtLookup << getAsMatrix;
dtLookup << New Column( "row_lookup", set each value( Row() ) );
row()=50;
// add column with neighboring rows
Eval (Eval Expr(dtLookup << New Column( "neighbors",
	Expression,
	set each value(
		{neighbors, dist} = tbl << K nearest rows( 8, Row() );
		neighbors[Where( dist <= Expr(max dist) )];
// map the neighbors to the main table
dt0 << Update(
	With( dtLookup ),
	Match Columns( :X_Die = :x, :Y_Die = :y ),
	Add Columns from Update Table( :row_lookup, :neighbors ),
	Replace Columns in Main Table( None )
wait(0);
t1=hptime();
// split the table to find the rows faster
// to speed things up, one could do the neighbours averaging here, but that's not the target
mySubsets = dt0 << Subset( By( :Lot, :Wafer ), All rows, Selected columns only( 0 ), Private( 1 ) );
// why is this SOOOOO slow !??!
For Each( {myTable}, mySubsets,
	myTable:neighbors << set each value(
		input = :neighbors; // take the neighbors from the lookup table
		Transform Each( {myRow}, input, // and replace them with the neighbors of the actual wafer
			result = :row[Where( myTable, :row_lookup == myRow )];
			If( N Items( result ),
				result[1],
//merge the subsets and map the neighbors back to the main table
tmp = mySubsets[1] << Concatenate( mySubsets[2 :: N Items( mySubsets )], Private() );
For Each( {myTable}, mySubsets, Close( myTable, noSave ) );
dt0 << Update(
	With( tmp ),
	Match Columns( :Lot = :Lot, :Wafer = :Wafer, :X_Die = :X_Die, :Y_Die = :Y_Die ),
	Add Columns from Update Table( None ),
	Replace Columns in Main Table( :neighbors )
Close( tmp, noSave );
wait(0);
t2= hptime();
// now use the cool new column
dt0 << New Column( "Defects average", Formula( Mean( :Defects[:neighbors] ) ) );
t3=hptime();
print("create lookup", (t1-t0)/1000000);
print("correct the rows", (t2-t1)/1000000);
print("calculate neighbor average", (t3-t2)/1000000);
Level XIII
wait(0);
t0 = hptime();
// get the coordinates
dtLookup = dt0 << Summary(Group( :X_Die, :Y_Die ),output table name( "xyLocations" ), Private);
dtLookup << Delete Columns( :N Rows );
Eval (Eval Expr(dtLookup << New Column( "neighbors",Vector,
	Expression,
	set each value(
		{neighbors, dist} = tbl << K nearest rows( 100, Row() );
dt0 << Update(
	With( dtLookup ),
	Match Columns( :X_Die = :X_Die, :Y_Die = :Y_Die ),
Close(dtLookup, noSave);
wait(0);
t1=hptime();
//map the rows from the lookup table to the correct rows
// so complicated ?!?!
dthelp= new table("help", add rows(col maximum(myTable:row_lookup)), new column("row_lookup",set each value(row())), private(1));
dthelp << Update(
	With( myTable ),
	Match Columns( :row_lookup = :row_lookup ),
	Add Columns from Update Table( :row ),
		Transform each({row},input, dthelp[row,"row"]);
	close(dthelp, noSave)
dt0 << Delete Columns( :neighbors );
dt0 << Update(
	With( tmp ),
	Add Columns from Update Table( :neighbors ),
wait(0);
t2= hptime();
wait(0);
t3=hptime();
