theo_beluzzi
Naming subsets in JSL
Hi!
I have a large dt, and want do make subsets from a column. I've managed to do it, but the subsets have all the columns locked. How I can unlock them in the code?
Also, how can I specify it's names, so I can work with those later?
dt2 << (Subset(
                   By( :Filial ),
                           Selected Rows( 0 ),
                           columns( :Cod. Cliente DPK,
                                         :Desc. Município Cadastro,
                                         :Desc. Cliente,
                                         :Desc. Tipo Cliente N1,
                                         :Desc. Tipo Cliente N2,
                                         :Name( "Sum(Vlr. Venda Comercial)" ),
                                         :Name( "Sum(Vlr. Lucro Bruto)" ),
                                         :Mg Bruta
ian_jmp
Level X
Re: Naming subsets in JSL
Depending on what you want to happen next, there may be a better way to do what you have in mind (maybe using a data filter instance). But, if you want or need to use 'subset', try something like:
dts = dt << subset(By(:sex), Columns(:name, :age)); // Using 'By' makes a subset table for each level in the hspecified column. 'dts' is a list of associated table references
// Change the names of the subset tables
dts[1] << setName("Females");
dts[2] << setName("Males");
ian_jmp
Level X
theo_beluzzi
Ooh, that's great!
I just want to break the original dt in others, and work with each in different ways... That's the best way of doing the separation?
Another question: when working with each of the subsetted tables, how i specify them? By dts1, dts2, etc.? Or I can also determine that?
