natalie_
Level V
JMP adding characters to string?
Hi all,
I had some code that extracted some numbers into variables, and then I put them together in a string.
xlocation = dt1:Die_X[x];
ylocation = dt1:Die_Y[x];
site = dt1:Site[x];
deviceName = "x="||char(xlocation)||" y="||char(ylocation)||" Site"||char(site);
It would output something like this:  x= 8 y=2 Site2
But now it outputs this:  x=[8] y=[2] Site[2]
I am not sure what I changed.  The columns in the data table where I am extracting the variables are Numeric columns.
Does anyone have any ideas why this might be happening?  Also, I am having trouble finding an example of how to use the remove from character function.
Something like this?  xlocation = Remove From(xlocation, [)?
pmroz
Re: JMP adding characters to string?
What's the value of x?  It seems that it's a list or matrix of numbers, which is then returning a matrix back to xlocation, ylocation and site.
Might have to insert logic to test x.  If it's a matrix extract the first value and use that.
a = [1];
b = char(a);
print(b);
"[1]"
pmroz
a = [1];
b = char(a);
print(b);
"[1]"
Craige_Hales
Is the column a JMP 12 expression column holding a matrix?
Here's a debugging idea that might shed some insight.  The type() function will tell you the data type of the value in a JSL variable.
x=42;
show(x,type(x),char(x));
x=[3.14];
x = 42;
Type(x) = "Number";
Char(x) = "42";
x = [3.14];
Type(x) = "Matrix";
Char(x) = "[3.14]";
Craige
natalie_
Level V
Thanks PMroz and Craige,
It was a matrix.  No idea why it suddenly changed to a matrix though.
