29755
Name Unresolved: Framebox in access or evaluation of 'Framebox'
Hi all,
I am trying to create a function and I don't know what seems to be the problem why it keeps on prompting the error Name Unresolved: Framebox in access or evaluation of 'Framebox' , Framebox( 1 ) /*###*/
Please help
bivpolyfit = Function( { x_param, y_param, grouping },
	biv = Bivariate( X( Column( x_param ) ), Y( Column( y_param ) ), by( Column( holder ), Column( type ) ),
	GroupBy( column( build ) ), << Fit Polynomial( 2, {Line Width( 2 )}));
	rbiv = biv << Report;
	rbiv[Framebox( 1 )] << {Marker Size( 3 )};
	rbiv[Axisbox( 2 )] << Tick Font( style( 0 ), size( 9 ) ) << Show Major Grid( 1 ) << Show Minor Grid( 1 ) << Show Minor Ticks( 1 ) << {Min( eval(xmin[j]) ), Max( eval(xmax[j]) )/*, Inc( incr[j] )*/};
	rbiv[Axisbox( 1 )] << Tick Font( style( 0 ), size( 9 ) ) << Show Major Grid( 1 ) << Show Minor Grid( 1 ) << Show Minor Ticks( 1 ) << {Min( eval(ymin[j]) ), Max( eval(ymax[j]) )/*, Inc( incr[j] )*/};
	rbiv[TextEditBox( 2 )] << Set Font Size( 10 ) << Set Font Style( "Bold" );
	rbiv[TextEditBox( 1 )] << Set Font Size( 10 ) << Set Font Style( "Bold" );
	rbiv[Outline Box( 1 )] << Set Title( y_param||" vs "||x_param );
	rbiv["Polynomial Fit Degree=2 ?"] << Close All Like This;
	rbiv[Framebox( 1 )] << Row Legend( Column( grouping ), Color( 1 ), Marker( 0 ), Color Theme("JMP Default"), Continuous Scale( 0 ) );
	rbiv[Framebox( 1 )] << Row Legend( Column( build ), Color( 0 ), Marker( 1 ), Marker Theme("Solid") );
	rbiv[BorderBox(3)] << Delete;
	rbiv[BorderBox(2)] << Delete;
	pbiv = rbiv[OutlineBox( 1 )] << get picture;
Re: Name Unresolved: Framebox in access or evaluation of 'Framebox'
You should find a list of display box references stored in biv. So you need to iterate over the list. You code looks good but it should be inside this loop through the list.
The Bivariate platform kicks out a separate report for each of the BY Groups.  Therefore your reference to rbiv needs to reference which of the reports to access.
rbiv[1][Framebox( 1 )] << {Marker Size( 3 )};
