Tatjana-MKS
Multiple Series Stack not working properly in JMP Pro 19.3
Hi, I’m having an issue with the Multiple Series Stack option.
When I activate this setting, the number of stacking columns does not update or change. Could you please advise what might be causing this or how to resolve it?
Re: Multiple Series Stack not working properly in JMP Pro 19.3
Does it work in other JMP versions? Very difficult to say what could be the issue without seeing the data and what you expect to have.
Normal stack
Multiple series stack with number of series 2 (non-contiguous)
Using JMP > Reshape Your Data > Stack Columns in Data Tables > Example of Stacking Columns into Mor...
