ERoderz
Multiple File Importer opening 2 tables?
I'm attempting to import data from multiple (almost identical) .csv files using the MFI, which I have scripted as   dt = Multiple File Import(  ....
I have "Stack Similar Files" checked, selecting data from row 270, with the correct delimiters, but for some reason it is creating 2 separate files, one of which is nonsensical. The other is what I need. I checked and all files have the data I need in row 270.
Anyone have a problem with this?
I could get around this if I knew how to rename that second table. The second table is created with a 2 at the end of the file name, Analysis. How do I assign a name to that table that was generated that isn't the original "dt" that I assigned with the Multiple File Import.
I think I'm just rusty on JSL and could use some help. Thanks all!
mmarchandTSI
Re: Multiple File Importer opening 2 tables?
If you know for sure the name of it, you could just do this:
dt2 = Data Table( "Analysis 2" );
dt2 << Set Name( "Analysis" );
Obviously, if there's any chance of another open table having that name it'll screw everything up....
mmarchandTSI
Multiple File Import returns you a list of table refernces. And you can get the table names using << Get Name if you really need to, but references should be enough
mfi_results = Multiple File Import(
	<<Set Folder("$SAMPLE_DATA"),
	<<Set Name Filter("Big Class*.jmp;"),
	<<Set Name Enable(1)
) << Import Data;
Show(mfi_results);
dtnames = mfi_results << get name;
If you need to you can get the references (and names) of all open tables using
dtlist = Get Data Table List();
