RVhydrA
Moving minimum (moving window)
Does anyone know how to calculate a moving minimum (or for that matter how to iteratively select X number of lag rows and do anything to them such as calculate a min, max, range, etc. In this specific example i want to look back over say the last 100 rows and get the minimum value, then move to the next row down and do the same again (over and over).
vince_faller
Re: Moving minimum (moving window)
Would something like this work?
Names default to here( 1 );
dt = open("$SAMPLE_DATA\Big Class.jmp");
dt << New Column("Min height 5 back",
	Formula(
		Min( // since we want a minumum
			:height[// the column we want the minimum of
				// a slice of the current row minus 5 (minimum 1 so it's still on the datatable)
				// and current row
				Min( Row() - 5 )::Row()
Vince Faller - Predictum
Monomorphist
The macro below isn't particularly elegant, but will do the job.
For ( i= 100, i <= N Rows ( dt ), i++,
 dt << Select Rows (Index (i-99, i));
 dt << Subset(
	Selected Rows( 1 ),
	Selected Columns ( 0 ),
	Output Table ("out")
Current Data Table ( Data Table ("out"));
x = Col Minimum ( :YourDataColumn );
Close ( Data Table ( "out"), no save);
Column (  "YourMovingWindow" )[i] = x;
Sub-setting the selected data, the way I've done it, is slow. Perhaps another user has a better idea how to access the selected data and extract the desired product.
I also wonder how a column formula could look like to achieve the results without a macro.
Cheers,
Kofi
vince_faller
	Formula(
				// and current row
