jetpeach
Moving column group to 'after column' is only moving it to the first
​I'm trying something that seems simple - moving a column group to a location after another column.
Moving "to last" works, "to first" works, but after doesn't for me, no matter how i mess with format.
Below is example code to test -
dt = Open( "$SAMPLE_DATA/Cities.jmp" );
dt << group columns( "xy", {:X, :y} );
dt << group columns( "pollutants", :Ozone :: :Lead );
dt << move column group( to first, "xy" );
this worked but if
dt << move column group( after("Latitude"), "xy" );
instead of the "to first"
then I get very strange behavior - BOTH the groups move the first location in the dt.
Re: Moving column group to 'after column' is only moving it to the first
This thread is rather old, but in case anyone stumbles upon it, i would like to document that this issue was reported to our JMP Development team, and the issue was addressed in JMP 14. All the script lines in the original post which are marked "not working" are actually working now.
Move Column Group does not have the "after" argument like  Move Selected Columns does.
However, you can select the group, and then use
     dt << Select Column Group("xy");
     dt << Move Selected Columns(after("?????"));
altug_bayram
I can confirm that your solution Jim does indeed work....
