anandk
Moving average and Weighted moving average on a data set
I am trying to do a moving average and a weighted moving average on the data set that I have posted below.
I want to do a moving average to the 'Mean' column.
Also can I repeat this formula by the 'Sample' group in my data set
14 REPLIES 14
anandk
Re: Moving average and Weighted moving average on a data set
I am not seeing the Col Moving Average function in JMP 12
The Col Moving Average() function was added in JMP 13.  So, for JMP 12 you will need to used the code I provided.  And all you need to do, is to add the division by 16 to the code.  Make sure you divide the 1,2,3,4 lag subsets with the appropriate subset the the 16
anandk
If( :sample != Lag( :sample, 1 ) | Row() == 1,
counter = 0
counter = counter + 1;
If(
counter == 1, :Mean1,
counter == 2, Mean( Lag( ::Mean1, 1 ) * 1, Lag( ::Mean1, 1 ) * 4 ) / 16,
counter == 3,
Mean( Lag( ::Mean1, 1 ) * 1, Lag( ::Mean1, 1 ) * 4, Lag( ::Mean1, 1 ) * 6 )
/ 16,
counter == 4,
Mean(
Lag( ::Mean1, 1 ) * 6,
) / 16,
Mean(
) / 16
Will the formula look like this or I have to divide the Lag of weights 1 and 4 by 5 and so on?
For the cases where "Counter" is less than 5, you need to adjust the divisor down to the sum of the weights for each of those levels, so the code should look like:
	counter = 0
If(
	counter == 2, Mean( Lag( ::Mean1, 1 ) * 1, Lag( ::Mean1, 1 ) * 4 ) / 5,
	counter == 3, Mean( Lag( ::Mean1, 1 ) * 1, Lag( ::Mean1, 1 ) * 4, Lag( ::Mean1, 1 ) * 6 ) / 11,
	counter == 4,
		Mean( Lag( ::Mean1, 1 ) * 1, Lag( ::Mean1, 1 ) * 4, Lag( ::Mean1, 1 ) * 6, Lag( ::Mean1, 1 ) * 4 ) /
		15,
	Mean(
	) / 16
anandk
I dont see the Col Moving Average function in JMP 12
