FR60
Moving average and EWMA
Hi
Given a column with numerical values I would like to calculate the MA in this way:
MAi=1/N*SUM(j=i-1 to j=i-w) Xj
where w is the window width, i-1 the starting element and i-w the last one. Les't do an example with w=2
t       x
1      x1
2      x2
3      x3        …..
4      x4        MA=(X3+X2)/2
5      x5        MA=(X4+X3)/2
6      x6        …..
7      x7
By using the New formula column-->Row feature
I set the Weighting to "equal". What about the Items Before and Items after to obtain what I reported before?
Same question if I want to use the Exponential weight.
Thanks  Felice
Re: Moving average and EWMA
Is the value of w equal to the number of columns in the data table, or is w equal to the number of the columns displayed on the screen, regardless of the number of columns in the data table?
FR60
Hi Jim  w is not dependent on the number of column.
Thanks  Felice
if it is a simple moving average, you can easily compute it by using the Lag() function in Formula Editor.
Here below an example on how to calculate the moving average of previous 3 rows for Dissolution column in Tablet Production sample data table:
// Open Data Table: Tablet Production.jmp
// → Data Table( "Tablet Production" )
Open( "$SAMPLE_DATA/Tablet Production.jmp" );
// New column: Dissolution_MA3
Data Table( "Tablet Production" ) << New Column( "Dissolution_MA3",
	Numeric,
	"Continuous",
	Format( "Best", 12 ),
	Formula(
		(Lag( :Dissolution, 1 ) + Lag( :Dissolution, 2 ) + Lag( :Dissolution, 3 ))
		 / 3
// Report snapshot: Tablet Production - Graph Builder
Data Table( "Tablet Production" ) << Graph Builder(
	Size( 799, 452 ),
	Variables( Y( :Dissolution ), Y( :Dissolution_MA3, Position( 1 ) ) ),
	Elements( Line( Y( 1 ), Y( 2 ), Legend( 6 ), Row order( 1 ) ) )
Cheers, Massimo
See this function in the documentation and Scripting Index:
ih
Super User (Alumni) ih
It looks like you want equal weighting with 1 row before and 0 after.
FR60
Let me do an example
Let's suppose to have the sequence 1 2 3 4 5 6 7 8 9
Starting from 5 I would like to do do the average of previous w rows. For w=3
(2+3+4)/3
and not
(3+4+5)/3
Rgds  Felice
ih
Ah, sorry I missed that detail.  You can add a Lag formula around the Col Moving Average to accomplish this:
For your example:
New Table( "MA Example",
	Add Rows( 10 ),
	New Column( "Data",
		Numeric,
		"Continuous",
		Set Values( [1, 2, 3, 4, 5, 6, 7, 8, 9, 10] )
	New Column( "MA",
		Numeric,
		"Continuous",
		Formula( Lag( Col Moving Average( :Data, 1, 2, 0 ) ) )
Gives the expected result:
