Modify or Update an Add-in
This may be a silly question, but I can't seem to find the answer online. I created an add-in, which is saved as a .jmpaddin file in a folder. The JSL scripts function as expected when calling them from the add-in.
However, I made some modifications to the scripts, but they are not reflected when running them via the add-in, even after restarting JMP. I can't figure out how to open the add-in in edit mode to either reload the scripts or make other modifications.
Re: Modify or Update an Add-in
HI @ClassDendrogram ,
If you're on Windows, when you go to File > Open and find the jmpaddin file, there's an arrow that you can click that will give you the option to open using the add-in builder, where you can switch over the jsl script that is being used.
Thanks,
Ben
Reopen the .jmpaddin file, with the new jsl in it, and JMP will ask you if you want to reinstall the addin
Thanks,
Ben
Hi Ben,
Thank you! This worked.
Georg
Hi @ClassDendrogram ,
the .jmpaddin file is just a zipped file with all of the files neede by the addin.
If you have chosen to reference additional files, that will probably not be updated automatically, depending on JMP Version.
Which JMP Version are you using?
How did you generate your AddIn, by JMP Addin Builder? Create Add-Ins with the JMP Add-In Builder
When you added a script in Addin Builder as a file (in JMP <= version 18), you need to add it again, to make the change effective.
This may have changed in JMP 19, but I did not test so far.
Georg
