Jemster
Modal Box If Statement Not Assigning Value to Variable
Using the code below I offer the user the choice of 4 products to analyse.
I use an if statement to open the correct file for the correct product.
I also assign a number for a variable I will need at a later date.
When I attempt to print this variable I get an error saying Name Unresolved at line 18.
It appears time_mult is somehow not being properly defined.
win = New Window( "Product Choice",
	<<Modal,
	<<On Validate(x = cb<<Get(),
		If(x == 1, y="File Path 1" ; time_mult=24,
		   x == 2, y="File Path 2" ; time_mult=168,
		   x == 3, y="File Path 3" ; time_mult=168,
		   x == 4, y="File Path 4" ; time_mult=168,
	cb = Combo Box(
		{"Product 1", "Product 2", "Product 3", "Product 4"},
	Button Box("OK"),
	Button Box("Cancel"),
Print(x);
Print(y);
Print(time_mult);
The following test code works perfectly and seems to me to look almost identical. I was wondering if anyone can identify what's going wrong
win = New Window( "Combo Box",
	<<Modal,
	<<On Validate(x = cb<<Get();
		If(x == 1, y="/H:/Example Folder/File 1.xlsx" ; z=5,
		   x == 2, y="/H:/Example Folder/File 2.xlsx" ; z=63,
		   Stop()
	cb = Combo Box(
		{"One", "Two"},
	Button Box("OK"),
Print(x);
Print(y);
print(z);
Jemster
Re: Modal Box If Statement Not Assigning Value to Variable
I needed a semi colon at the end of line 3
The issue is that you have a comma after the statement instead of a semicolon
x = cb<<Get(),
The On Validate() function has only 1 element
On Validate( expr )
When there is a comma after the statement, JMP sees
On Validate( expr, expr );
and it executes only the first element
Jemster
x = cb<<Get(),
On Validate( expr )
