Mixture design via easy DOE
Good afternoon,
I would like to start a mixture design via the Easy DOE program but I don't succeed to put in in mixture mode. It seems to suggest only screening or response surface designs. Do you know how to set it up in mixture design?
Many thanks for your help
Re: Mixture design via easy DOE
EasyDOE currently does not support mixture designs.
JMP does support a variety of mixture designs via other platforms, though. You can check out different examples here: Overview of Mixture Designs
You will find examples for each design and how to generate them in the link.
Hope this helps.
Cheers,
Jonas
