Created:
Nov 13, 2022 11:24 AM
| Last Modified: Jun 10, 2023 1:53 PM(6416 views)
I was recently introduced to JMP as a student and have been using the trial version to see if this will be helpful for continued use. I've noticed that there are several missing features such as no access to K Nearest Neighbors under the Predictive Modeling menu or Association Rules, and no Validation field on the Partition window (screenshot below.)
Are these features not included as part of a trial or am I missing the option to activate these somehow?
The trial version is a full version of JMP. The capabilities you are describing here are in JMP Pro. The JMP 17 trial includes the full capabilities of JMP and is not limited. If you have further questions please don't hesitate to contact [email protected].
Connect with me on LinkedIn: https://bit.ly/3MWgiXt
If you are still a student, most major universities have unlimited access to JMP Pro for enrolled students and faculty. You can see a list of those institutions here University List | JMP.
Most often it is available through the university's main software site.
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '568637' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '568637') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '568637') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
