brandl22
Missing Validation Option on Fit Model Screen
According to documentation there should be a "validation" option under model fit. I am not seeing it. I have JMP 13.1.0.
Is there some kind of configuration I am missing?
Re: Missing Validation Option on Fit Model Screen
That is a JMP Pro feature. Are you using that version?
brandl22
I am thinking this may be the problem.
Also, you must select the Peronality, such as Standard Least Squares, before the validation role appears.
dale_lehman
As soon as you put your response variable in, the validation box should appear.  I'm not sure why it isn't there when you first launch the platform, but I suspect it is because there are many types of analyses that are done through the Fit Model platform and only some may support validation.
I don't think that all of the platforms accessible through Fit Model (i.e., Personality) support cross-validation, so the role only appears when you select one that does. Entering a continuous data column in the Y role selects Standard Least Squares automatically, which does support the validation role.
brandl22
Thanks all, pretty sure this is a versioning issue. I've tried every variable and every model and the validation model doesn't pop up for me.
Jeff_Perkinson
Getting back to the first response that @Mark_Bailey gave, the Validation role is available only in JMP Pro.
If you don't have JMP Pro, you won't have the Validation role.
-Jeff
