Microsoft Word Import to JMP
DunnTestsCat880
I am looking to automate importing tables from a word document into JMP without copy and pasting but am struggling with this as each table has a title, included in the rows of the table, that is above to the column headers I would like to use in JMP. Is anyone able to help with this at all?
Re: Microsoft Word Import to JMP
Have you tried if this works Word Import Tool
You might be able to save the doc as pdf and try importing with JMP.
I tried it for a simple table. Auto detect may work. I had to select it (draw.box around it) for a simple table.
You should see the preview in the Workflow builder
I have tried the word import tool, but unfortunately it doesnt recongise the tables properly as they are laid out as above. I would like the second row to be the column titles, and the thrid row to be the column data (and the first row to be ignored compeltely!
No recommendations found
