billi
Level V
Mediation analysis in JMP
 Is there an option for mediation analysis in JMP? Mediation analysis can be done in SAS using PROC CAUSALMED.
jules
Re: Mediation analysis in JMP
Hi @billi,
Mediation analysis is not yet directly available in JMP (as of JMP 14). However, with a little bit of work, you can bootstrap an interval estimate for the indirect effect of a variable using the Right Click > Bootstrap functionality in JMP Pro. So, the answer is: possible, just not yet easy.
I encourage you to post your request in the JMP Wish List so our developers know there is interest in adding this functionality directly into JMP.
@jules
jules
Hi @billi,
@jules
billi
Level V
Thank you @jules for your reply. I added this to wish list as well.
Juter
Vote to add mediation analysis to JMP. The poll is open here Mediation analysis in JMP
