I initially mis-read 'median' as 'mean' and wrote the following: It takes a few seconds on my Mac, but almost all of that is in making the example table:
NamesDefaultToHere(1);
// Make a table with 'nc' columns and 'nr' rows to use . . .
nc = 1000;
nr = 57;
dt = NewTable("MAD Example");
for(c=1, c<=nc, c++,
	dt << NewColumn("Col "||Char(c), Numeric, Continuous, Formula(RandomNormal(0, 1)));
dt << addRows(nr);
dt << runFormulas;
// Start Here: Calculate MAD for each column . . .
dt = CurrentDataTable();
mat = dt << getAsMatrix;
// (1): Get the mean of each column in a row vector
mean = VMean(mat);
// (2): 'Explode' this to make a matrix congruant with 'mat'
meanMat = Repeat(mean, nr);
// (3): Get the Absolute deviations
AD = Abs(mat - meanMat);
// (4): Get the MAD
MAD = VMean(AD);
// Find the column numbers of the 'nc2' columns that have the biggest MAD values
nc2 = Round(nc/10, 0);
rankMAD = Rank(MAD);
topRandMAD = rankMAD[(nc-nc2)+1::nc];
// Make a second table
dt2 = NewTable("Top "||Char(nc2)||" Largest MAD Values from "||(dt << getName),
			NewColumn("Column Number", Numeric, Nominal, Values(topRandMAD)),
			NewColumn("MAD", Numeric, Continuous, Values(MAD[topRandMAD]))
In addition to @txnelson approach, I note that the Distribution platform will give the median absolute deviation. With 800,000 columns I might expect his approach to be quicker though.
